1 second pulse
ged
Jun 2010
Sydney
18
Hello, I am using step7 and I require a one second pulse. I don't think there are any system bits that I can use. Does any one have a suggestion? Thanks
Yes, there is a system clock memory byte.
You need to enable it in hardware config of CPU in the tab Cycle/Clock Memory - on the bottom of the tab.
And on specified byte, You'll find clock bits.
For example bit 0 is 0.1s long, bit 5 is 1 second on/off and bit 7 is 2 secons on/off.
Very new to PLCs, I am trying to add a delay to a simple motor setup. I want the motor(just name I gave to output) to be able to go on for 5...
4,210
Dear All, We have to read the time gap of two rising pulse which is in micro second how can we do it in plc.(any plc) thanks in advance.
2,164
please help what is the equivalent of m8013 of Gx developer in KV builder? i need to have a one second pulse. also can't find the comparator...
1,477
hello guys is there any 1 millisecond pulse generator in the rslogix5000 inbiult
10,028
Hi all, Anyone knows how to declare a one second pulse in the Rslogix 5000? Is there any command for this function? It does not same like GE or...
34
86,604
