1 timer traffic light problem
Ceaser22ny
Aug 2018
new york
i been at this for 2 days. The code for the traffic light works great. The problem is the programming of the crosswalk button. Im so close or so far depending how u look at it. Here is the criteria
When depressed, the crosswalk push button will cause the appropriate Walk Sign to be illuminated at the next occurence of a Red to Green transition for the appropriate direction.
If the Green light is already illuminated when the button is pressed then the Walk signal sequence will be delayed until the next Red to Green transistion ocurrs.
Once the Walk Sign is illuminated, it will remain so for the duration of the Green signal.
When the Amber light appears, the Walk Sign will commence to flash On and Off and continue to do so until the Red signal appears.
I got most of it to work the problem im having trouble with rung 2 keeping the dont walk sign to stop flashing if the button is not pushed
Hey there, I have been doing all these exercises until this one where you have to control the pedestrians aswell. So my question here is, how do...
3,435
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
97
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
328
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
443
why my timer only executes once here? After first time i use it, ET stays at 0ms all the time. It is in FB
320
