10 Panel View connect with a SLC or Compact Logix
huynt
Nov 2004
106
Dear All.
My new project for Truck loading System(Oil terminal) with ten Loading Arm.
I want to use ten PanelView for ten loading arm( start, stop loading and display running data). Panelview connect with one SLC or Compact logix. But, How many PanelView can connect with SLC(or Compact Logix) and protocol(DH485, DeviceNet, Controlnet) to use?.
Help me!
Thanks.
Ethernet would probably be the best choice. The CompactLogix 1769-L32E supports 32x CIP connections. RSLinx Enterprise can open between 2-5 CIP connections, a max of four CIP connections for read tags (depending on the volume) and one CIP connections for write tags.
The 1768-L43 processor with a 1768-ENBT module will support 64 CIP connections. This might be a good way to go if you plan to connect 10 PanelView Plus terminals to a single CompactLogix Processor.
ControlLogix would also be a good choice for ethernet.
1756-ENBT supports 64 CIP connections
1756-EN2T supports 128 CIP connections
Good afternoon PLCS.net! I have a very odd situation that is happening, and hoping someone has some insight. We have just laid out a new 10G...
665
Hi all, how many plcs can allen bradely panel view hmi connect get data for mimics
7,058
hi.i dont have a port for upload and download program to my panel view 1000 and i want make a proper cable.could somebody please help me?
3,281
Hi, I´m trying to connect a panel view plus 400 with a 1756-L61, and I would like to know if anyone did it already, and tell me how to do it, I...
7,645
well I need to connect the PV+ via serial I tried but always the same problem "the destination selected is not a valid device" I'm using a 5/04...
17
18,695
