10 Pole Relay
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone!
Short and simple questions, I have one PLC output, that I want to wire to 10 different devices.
Does anyone know of a relay that has 9+ Normally Open poles?
Thanks,
Paul
Allen Bradley
700-CF400D relay 120V coil
100-SA20 left side contact block
100-SA20 right side contact block
100 FA 40 front mount auxiliary contact block
12 poles
I would probably use a bank of these with common bars to make them all actuate at the same time.
https://blog.phoenixcontact.com/mar...ct-plc-interface-relay-is-no-1-in-the-market/
We have started using Automation Direct 78 series relays on some in house panels for the last 18 months. Over that time, four 784's have had one...
3,650
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
Hi I have an IEC motor 4pole motor 50Hz 5.5kw. It is stamped with 1540rpm. Is this even possible for a 4-pole motor?
3,328
I apologize in advance if this is off-topic, but I really need to understand what's going on... While doing some renovations, it was found...
20
5,577
I am designing a machine for use in the European Union. The machine will include a Ropex heat seal controller that will receive a 230VAC single...
40
7,383
