4pole motor 50Hz
Karsten
Feb 2006
Odense
158
Hi I have an IEC motor 4pole motor 50Hz 5.5kw. It is stamped with 1540rpm. Is this even possible for a 4-pole motor?
The base speed on a 4 pole 50Hz motor is 1500 rpm
n = f (2 / p) 60 (1)
where
n = shaft rotation speed (rev/min, rpm)
f = frequency of electrical power supply (Hz, cycles/sec, 1/s)
p = number of poles
so it would not be possible to have run at 1540
but if it is a 60 Hz motor the base speed would 1800 rpm
1540 would be a very high slip motor if it slipped that far it would run very hot
so the numbers don't make sense
Not so if its a generator then for a 4 pole it would need to be driven at 1500 rom for 50HZ
and 1800 rpm for 60 HZ
The number of pols, Hz and the RPMs will still be the same weather is a motor or a generator
again the numbers as posted don't make sense it think the numbers got transposed
1540 should be 1450 that would make sense that would be about .05 % slip
or 50rpm slip under load sounds about right
An asynchronous induction motor if it acts as a generator will rotate at more r.pm. than the frequency revs.
If it were a synchronous generator it would spin at the exact frequency revs.
But I also think that the one who printed 1540 was wrong.
From the manual
60 Hz. - 1850 RPM, NL to 1800 RPM, FL
50 Hz. - 1540 RPM, NL to 1500 RPM, FL
it's a generator not a motor no load RPM 1540 for 50HZ
that 40 rpm slip from no load to full load
the frequency will be a little higher at no load
obviously not intended to line synced
1540rpm
Hi All,
Yes, turns out that is is a generator that shall be run as a motor. The way I see it it is a standard motot respeced.
One thing that is strange is that they specify Locked Rotor Time:
12s(hot)
22s(cold)
I have never seen this specified on a motor why would that be specified here? If running as a motor will it stay in locked rotor state for 12-22s or is that max permissible?
Guessing here, but I would assume that is the max permissible. Seems like a long time but that thing may be a tank.
If you know how to do it (and I most certainly don't) you can use those two numbers to develop a thermal model of the motor/generator based on a given current through it and an assumed ambient temperature. If you know how it heats up you can figure out how it cools down as well.
Keith
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
49
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
296
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
156
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
357
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
221
