sprek
I am having a problem with a 110 vac capactitive prox leaking enough voltage to always light an indicator. This started when the original bulb type was switched with an led. The led doesnt use enough load to pull the AC down to near zero. The output of the prox goes to the indicator and an input to a ML1500 PLC.
Does anyone have an idea what I can do to pull the voltage down?
