110 VAC power line filters
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
Hi all,
i am working on a project in which i need line filters on the 110 side of the controls.
my search for line filters gave a wide range of topics but with no real luck.
my temperature range is maxes out at around 140 inside the panels.
the standard one i use doesn't reach that temperature.
what brands do you use / who would you recommend?
thanks in advance.
james
I have used Transtector in the past. The DR series is DIN Rail mounted and is rated to 85 deg. C.
Edit: The model I have uses is the I2R ICP. They are good to to 80 Deg. C.
Good Morning , I have a quick project to do , I know it is not a good practice , but can you put a shielded 120 ac cable in the same...
5,290
Hi all, If you are in a corrosive environment, are 110 VAC devices (like relays, contactors, you name it) a better option than the 24 VDC...
2,397
I am having a problem with a 110 vac capactitive prox leaking enough voltage to always light an indicator. This started when the original bulb...
2,629
As the title says I am looking for an Audio Alarm. The ones we use normally are 24 V, but I need a 110 VAC one. Automation Direct has some 22mm...
2,245
Hi All, I do have a project using FX5U-32MR/ES PLC & GS2110-WTBD-N HMI. I am using GT Designer version 1.109P. However, there is an error during...
1,440
