1250 panelview plus password problem
sparky64
May 2003
Newcastle upon Tyne
127
We can't log in using our passwords, and i belive it's because someone has downloaded the .apa file which uses passwords on the laptop instead of downloading the .mer file which uses the passwords in the project file.
can anyone shed any light on this?? is there a way around this.
sorry for the lack of information but i'm not too familiar with panelview plus.
sparky
If you can get connected to the PVP, (or you can go in the Configuration mode and use a CF card to load a new application), you may try to download the right .mer file, with the setting to run application when download finish.
This will run the file you can manage with your password; after that, you may change the Startup setting in Configuration mode to run the new application and also delete the wrong one.
Hope this helps,
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Hey guys, I'm at a bit of a loss with a problem I'm having with some PVP 1250s and hoping for some advice. In firmware and application version...
299
is it possible to comunicate a powerflex 753 (ccw) using ethernet 20-750-ENETR card to a panelview plus 6 1250 (factorytalk view studio me)...
1,500
Hello, I recently installed an **** Flexy 201 so we could monitor our PLCs (one SLC 500 and one Control Logix) remotely under a VPN. One of the...
2,365
Hi, I have a customer that has an intermittant issue with a PV+ (2711P-T12C6D1) and they would like to replace the PV+ with the latest PV+7...
2,997
I have these PLC and HMI and want to communicate them. I made a program in RSLogix5000 and FactoryTalkViewStudio, tried them out with FT station...
4,422
