How to run a VNC Server on a PanelView Plus 1250
acampos
Apr 2017
Clifton, NJ
Hello, I recently installed an **** Flexy 201 so we could monitor our PLCs (one SLC 500 and one Control Logix) remotely under a VPN.
One of the features that it has is the ability to broadcast the HMI screen to any device with a browser for remote monitoring. This requires the PanelView Plus 1250 (each PLC uses this model) to run a VNC server.
I was using this page to instruct me how enable the VNC it: https://theautomationblog.com/remotely-controlling-your-a-b-pvplus-using-vnc/
Unfortunately when I get to the part where you activate the VNC server, I find the option is grey, not red, which means it is "not available on this platform".
Does anyone know how to get it working?
I believe I read that I can load it and install it, but I'm not sure where to find the program. I found many open source VNCs online that are compatible with Windows CE, but I would like to see if I could get the official Alton Bradly software before trying something open source.
I also tried using the View Point service, but Factory Talk View ME isn't installed either...
Thanks in advance for any suggestions!
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
77
I have a few questions about Studio5000. 1. Why is my RA folder so big? its well over 100 GB. 2. How do you delete versions or extra files...
279
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
352
