1395 Digital DC Drive AB digital output "zero speed"
Programmer4
May 2009
Tennessee
29
HI,
I have studied the manual for this zero speed digital ouput relay contact. P558. The contact is suppost to close when the drive is at zero speed and I can see bit 10 at 1 on the hand held, but this contact does not close when reading it with an ohm meter. Can I get some instruction on how to set this up?
The "default" setting is "At Zero Speed", but it can be changed. Perhaps someone set it up for a different function?
From the Discrete Adapter Board Installation & Operation Manual (LINK):
Parameter558 - [A> Digital Out 1]
508 - [B> Digital Out 1]
Use: Maps Digital Output 1
Program Terminal Units: None
Maximum Value: 15
Minimum Value: 0
Default Value: 10
Description: This parameter has a range of 0 to 15. It establishes which bit
of Discrete Output parameter 450/350 controls the Output 1 relay. When
the bit is set the relay contact closes. The default value for this parameter is
10 which is the bit corresponding to “At Zero Speed” when parameter
450/350 is linked to Logic Status.
-Eric
I read this before
Maximum Value: 15
Minimum Value: 0
Default Value: 10
-Eric
I read this before, but I didn't really understand it. I have the hand held terminal for this drive and I don't know how to even get to the parameter with it so I can see them. I now that it is set to default 10 for zero speed, but the contacts do not actually close for whatever reason.
I am having trouble undestanding what is happening in two of our drives on our ERW strip prep line. The drives are issued start/stop/jog commands...
3,689
We have 8 1395 drives (1395-B73N-C2-P10), all running on a 0-10v control loop. We need to make these drives last at least 3 more years until the...
5,350
I am having to recreate a PLC5/40 program from a paper copy. Unfortunately there is no documentation on how to setup the 1395 drives with RIO...
1,552
I have a 500 hp. Drive that has a field loss fault. changed drives, no help. Changed motor, still has field loss fault. put a resistive load on...
4,144
Hi there: I'm hoping someone out there is still familiar enough with the Allen Bradley 1395 drives to help me out. I've been trouble shooting...
3,585
