1734-485ASC module configuration on EtherNet
narenperth
Jun 2011
Perth
Hi guys,
Have anyone configured 1734-485ASC Module connected to ControlLogix PLC L63 via 1734-AENT Module.
I have a RFID Reader which is wish to connect to PLC using RS485 output from the reader.
Cheers!!!
I've used the 1734-232ASC and 485ASC.
What sort of input and output strings do you need to and from the RFID reader ?
The xxxASC modules work best with ASCII that has delimiters, like CR and LF characters. It's pretty good with fixed-length character sets, and weak with variable-length data that lacks delimiters.
Hi Ken,
My application only needs to read data from RFID Reader.
String BODY is as below
STX ----- DATA ----- ETX
Data Start Sign STX=02H, Data End Sign ETX=03H;
Data is: Antenna Code (1 Byte) + Tag ID (8 Bytes), length is 9 bytes ASCII.
I got following string input
100000000020110602004910 (Reader2600_tag_ID on reader’s software)
01100000000020110602004910 (Hyperterminal_Readout)
$0201100000000020110602004910$03$FF (PLC_Readout on ControlLogix L61 serial port)
I wish to make this work via 1734-485ASC module on a 1734-AENT Chassis.
Not sure is 02 and 03 be start and end delimiters.
Have set the delimiters as 2 and 3 but still doesn’t work. 
Hello, Is it possible to upgrade firmware version of 1734-485ASC module from 3.1 to 4.1? If yes - How? Regards, Punit
1,240
Hey all, Warm wishes to all of the season :) Ok, so I have a few(25) temperature controllers which have RS485 ports for communication. The...
4,279
Hi guys, Have anyone configured 1734-485ASC Module connected to ControlLogix PLC L63 via 1734-AENT Module. I have a RFID Reader which is wish to...
1,362
I have only been at this 3 months and I recieved a curveball. My cabinet is finished and shipped but I was just informed that feedback which was...
3,251
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
87
