1734 ADN point i/0 adaptor
jcperdue
Feb 2013
Indianapolis, IN
I have installed the 1734 ADN point I/O Adaptor. My system power Let is off, but I measure 24V with my Fluke? Shouldn't I at least be getting the green Led?
Are you measuring at the DeviceNet connector, or at the removable terminal block ?
I think the System Power LED indicates the presence of power at the removable terminal block plus an active DC/DC converter to supply the Adapter's logic and the 5V PointBus supply.
The Field Power LED is upstream of the DC/DC converter and shows the presence of 24V bulk power at the removable terminal block, which is then connected to the local POINT power bus.
DeviceNet power is totally separate and isolated from the Field Power and System Power, and should come from a different power supply.
I am a beginner on the AB platform and I have a question. I have a 1769-l32e with scanner devicenet,I am presented with the offer to buy a point...
1,727
Hello all, We have compactlogix CPU with 1769 SDN scanner. The scanner is connected to two nodes 1734 ADN .Every now and then ADN fails with...
3,686
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,228
I'm playing around with some DeviceNet stuff on my test bench and just got a 1734-ADN. I forgot the ADN was AutoBaud, so that's a nice feature...
1,762
Guys How would I configure a 1734 ADN ethernet adaptor module in device net? In the parameters dialog box, would it be an input plus all the...
1,866
