witdog2020
I have an issue with this 1734-aent, This has been an existing set-up. The 1734-AENT 192.168.1.2 card has been configured through Bootp with the correct IP address, it shows up in linx under the the adaptor module, also uploaded the EDS file just fine.
It is going through a gateway, all IP's are fine and correct, going to a compact logix 192.168.1.3 with another correct IP.
EXAMPLE ON IP's: 192.168.1.1 Gateway
I go into the Rslogix compactlogix tree, and it shows the I/O faulted, I try to right click on the faulted 1734-aent module and the program closes, either offline or online. The compact logix is fine no faults, just the I/O.
1769-l23E- QBFC1 CompactLogix5323e-qbfc1 Controller
1734-aent rev 2.4 point I/O backplane set at 2
1734-IE2C ser. C analog card rev. 3.4
Can it be a corrupt program? Was working properly until 3 days ago, no changes I know of.
