1734-IE2C issues
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
Hi all,
This is my first time working with a 1734-IE2C analog module. I am tasked with wiring the flow meter into the analog card and the OEM is doing the programming via remote access. I have 2 wiring diagrams to choose from. I am connecting a Flomec model G2S15F 4-20ma flow meter to the analog input card. The unit is a 6 wire device. 24 volts for power with +/- 24 marked, 4-20ma with +/- terminals marked, and pulse output with +/- terminals marked, not used.
The unit has power and the wiring has been run to the input card. I am getting a signal failure on the hmi display.
The device is currently wired as follows:
Power is connected to the flow meter. I am using input 1. I am connecting a wire from the V terminal of the analog card to the 4-20 ma (-) terminal of the flow meter. I am then connecting the 4-20ma (+) of the flow meter to the input terminal of the analog card. See the attached picture.
Have i wired the sensor in incorrectly. Any Suggestions?
Thanks in advance,
James
On a 4 wire device the 4-20ma + should be wired to the input of the module. The 4-20ma - to the Common C on the module. The power to the device could come from the V and C terminal or an external power supply, depending on the load requirements of the device.
The way you have it wired is for a 2 wire loop powered device where the analog module supplies the 24v for the loop. You don't have that.
I am running out of real estate in my panel. I have several IE2C cards. I would like to convert them over to IE4C to create space. Rockwell...
1,348
Hello people, I have a 1734-IE2C module which reads a valve position. When the valve is 100% opened the channel data value is something about...
2,277
Hi Guys, We Have some problem with 1734-ie2c module with controllogix cpu, sometimes the input value went to 0 without Module alarm. suggestions...
1,522
We had encounter a problem regarding on our Allen Bradley 1734-IE2C, When we connect 1734-IE2C, to CompactLogix (L18ER), the PLC does not...
4,884
Hi, I need to replace a faulty 1734-ie2c card on AENT 1734 POINT I/O (Ethernet). Do I need to power down the unit and go for like for like...
2,415
