1746-HSCE vs 1756-HSC/B
bdb1324
Jul 2019
b
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large.
1746-HSCE uses M0:e.1/4 for a soft reset in the 1756-HSC would this be the same as O.ResetCounter.1?
1746-HSCE uses M0:e.1/12 as an enable/disable counter seems to be run during a first pass bit. I don't notice anything like this in the 1756-HSC can this rung be deleted?
Other than Nx moves (I believe can be done the same way between the two) is there anything else I should look into beside dip switch settings?
I have also attached how the 1746-HSCE referenced the soft reset and enable/disable.
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,025
Hi there, I have a machine where was a servo with extra encoder. That encoder had resolution 100ppr/5V. We did replace complet servopack (...
948
I have a SLC 5/05 processor and I am trying to reference an output from a High speed counter card to be used elsewhere in the PLC. The output...
1,639
Processor Error Message: G file configuration error.. user program G file size exceeds capacity of the module. I cannot seem to find any data...
2,039
Hey there, new to the forum. I have close to 15 used HSCE mod's for the SLC5/04 and I am wondering if there is a place I could sell them. There...
1,425
