1746-NI8 Issues
Dallyn Czar
Aug 2013
BC
Hi, I have an analog input card on a slc 5/01. Im pretty sure everything is configured properly and the dip switches on the back are set to 4-20 like i want. Now i have a c02 transmitter wired in to a channel just a two wire device fairly simple. My issue is that the Module Status is solid green light which is fine but the channel status flashes green. The allen bradley documentation says to check the status bits But as far as i can tell they are all 0. Anyone have any idea what could be the problem, i cant see it being wiring or i should at least have an over/under range fault. Thanks
Dallyn Czar,
did you write the plc code and supporting data files that initializes the card and card files it writes to?
see the insrtuction manual.
also, your 5/01 may not support that version of card if its an older 5/01
regards,
james
When i configured the card it automatically did that as far as i can tell, If i set the card up as class three the processor cant handle it but as far as i know i should be able to run it class 1 without any issues but i still have alot to learn so who knows. thanks
In the program you posted only channel 2 is enabled. Is that the one you are having trouble with?
Check and double check your wiring also put a meter in series with the channel input and check the current.
Don't know if this is relevant to your situation but I changed a 4-channel AI to an 8-channel version on an existing SLC rack where the current loop was configured as: +24V into the module, out of the module to the remote device and then back to 0V. I got the flashing green light. I had to invert the electrical configuration, referring the module's inputs to 0V, not +24V as it exceeded the NI8 module's common mode input voltage.
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
184
Hi everyone, I have a SLC 500 (5/04) with a 1746-NI8 Analog module input. I have two questions: 1. I have noticed there is a IN0-, IN0+ and...
3,515
Hi Folks I am wireing a 1746-NI8 analog card and I suspect the card is bad... unless I am missing something. I have the literature for the module...
1,852
Trying to read analog inputs from 1746-NI8 card, but values show 0 and channel status LEDs never come on. Details: - SLC 5/05, 1747-L551...
2,931
Wondering if anyone has seen this and possibly knows how to fix. We have an SLC 5/05 with an NI8 and an NI4 in slots 1 and 2 in the rack. Both...
3,493
