1746-nio4v termocouple
Adam303
Aug 2009
Chicago
587
Hi To All
I have a slc 500 5/04 processor AB. With that I'm using a 1746-NIO4V Analog i/o Card.
I have a project that needs to reed temp of a tunnel with a type J termocouple, and output will give a proportional 4-20ma to a electronic to paneumatic 3-20psi proportional transduser.
Any idea if i can use the 1746-NOI4V to reed the type J themocouple, if so how do i configure. If not what other Input Card can I use to reed a TC J input.
Thanks for You help.
The 1746-NOI4V will not accept thermocouple inputs. FYI this card is voltage output.
You can buy a thermocouple input card if you want. ( 1746-NT)
But if you only have one input or already have the 1746-NOI4V card then a temperature transmitter makes more sense to me. See link below for one brand. There are many,many more brands to chose from.
http://www.miinet.com/products/sg_temperature.shtml
Do you have the instruction sheet?
I learned the hard way TC make excellant antenna and will pick up EMI and screw up everything. I had it next to heaters. Make darn double sure you do not run TC near power cabling and in my mind put TC in a conduit not only for the shielding but for ease in replacement.
Dan Bentler
Hi Mickey. is the 1746scNI8u an Allen Bradlay Card?????
Card is made by Spectrum Controls ( don't know who actually manufactures it). They are a Rockwell Automation Global Encompass partner.
See first line on the link provided in previous post.
Heya guys, I'm looking to connect a Banner Q5XKILAF3000-Q8 (4-20mA) signal into my plc which have a analog input card 1746-NIO4V and was...
1,085
HI EXPERTS THIS IS THE FIRST TIME THAT I AM DEALING WITH ANALOGE MODULE 1746-NIO4V I HAVE CHECKED THE WIRING DIAGRAM AND ACTUAL PHYSICAL...
6,529
HI AND MERRY CHRISTMAS IN MY COMPANY WE HAVE A MACHINE WHICH CONTROLLED BY SLC 5/02 PROCESSOR AND ONE OF THE MODULE IN THE PLC SYSTEM IS ANALOGE...
5,196
HI PLC GUYS I HAVE SOME QUESTIONS FOR THOSE WHO ARE FAMILIAR WITH ANALOG MODULE 1746-NIO4V: 1 WHAT IS THE PURPOSE OF THE TERMINALS 6 AND 9 ON...
7,776
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
195
