AB ANALOGE MODULE 1746-NIO4V
PERSPOLIS
Jun 2002
ontario
295
HI AND MERRY CHRISTMAS
IN MY COMPANY WE HAVE A MACHINE WHICH CONTROLLED BY SLC 5/02 PROCESSOR AND ONE OF THE MODULE IN THE PLC SYSTEM IS ANALOGE MODULE 1746-NIO4V AND SET TO VOLTAGE INPUT AND VOLTAGE OUTPUT THIS MODULE FUNCTION AS:
1 CONTROL AIR PRESSURE OF THE SYSTEM WHICH WORKS FINE WHEN OPERATOR CHANGE THE AIR PRESSURE TO REQUIRED VALUE PRESSURE CHANGES ACCORDINGLY NO PROBLEM
2 THE OTHER FUNCTION IS TO INDICATE THE ARMATURE CURRENT OF DC MOTOR (DC INDICATING METER IS MY LOAD WHICH IS 50 MILI VOLT FULL SCALE DEFLECTION.
I HAVE CHECKED ON LINE INPUT AND OUT PUT WORK OK AS THE POT ON THE CONTROL TURNED CLOCKWISE THE RPM GOES UP WHCH WORKS FINE BUT I DO NOT SEE ANY THING ON INDICATING GAUGE TO SHOW THE CURRENT OF DC MOTOR AND JUST TO REMIND YOU THAT WIRING IS OK NOW MY QUESTION:
IS IT POSSIBLE THIS OUT PUT CHANNEL NOT FUNCTIONING PROPERLY EVEN THOUGH ON LINE MONITOR SHOWS EVERYTHING IS IN ORDER.
I LIKE TO ADD THAT ONE RESISTOR 20 KILO OHMS IS CONNECTED IN PARALLEL WITH THE INDICATOR
MANY THANKS EXPERTS FOR ANY RESPONSE
Have you verified the meter works? You can verify the output by using any multimeter, most have a MV option these days (especially digital multimeters).
AB ANALOGE MODULE
HI RSDORAN
I HAVE NOT BEEN ABLE TO CARRY THE TEST PROCEDURE AS THE MACHINE IS BEING LOCKED OUT FOR PM AND FOR THE TIME BEING I AM TRYING TO GATHER INFO BUT HOPEFULLY I WILL PERFROM THE NECESSARY TESTS.
MANY THANKS
PERSPOLIS
Basic Electricity
Meter movements are driven by current. Sensitivity is expressed as required current for full scale deflection. The common garden variety used in most multimeters is 50 microamps which yields the common 20Kohm/volt rating.
The multiplier resistor used to convert the meter from a current measuring device into a voltage measuring device is placed in series with the meter, not parallel. Parallel, or shunt, resistors are for changing the current range of the meter.
Assuming you have a 50 microamp movement and want to measure 0-10 volts, Ohm's law will quickly tell you that the circuit impedance should be 200K. Put that value in series with the meter. The meter's resistance is small by comparison and, for your application, probably insignificant.
BASIC ELECTRICITY
HI GERRY
PLEASE REFER TO SLC 500 ANALOG I/O MODULES USER MANUAL ALLEN BRADLEY PUBLICATION 1746-6.4 JANUARY 1996 SECTION 3.8 3.9
MANY THANKS
PERSPOLIS
HI GERRY
I assume you are referring to the following:
"voltage outputs (OUT 0 and OUT 1) of the NIO4V and NO4V
are referenced to ANL COM. Load resistance (R1) for a voltage
output channel must be equal to or greater than 1K ohms."
So, what is your point?
HI EXPERTS THIS IS THE FIRST TIME THAT I AM DEALING WITH ANALOGE MODULE 1746-NIO4V I HAVE CHECKED THE WIRING DIAGRAM AND ACTUAL PHYSICAL...
6,525
hi how are you, thanks to you i,m starting to create my own program now. i have two questions?? i,m using a melsec FX2n PLC i,m now trying to...
2,055
I have a omron cj1m-11cpu with: 3x cj1w-id211 (16 inputs) 3x cjiw-od212 (16 outputs) and a mad42 (2 anologe outputs 4 analoge in puts) I wrote a...
1,797
Hi gentlemen Is it possible to force an analoge value in these CPU before 400 what i notice is i cannot write PIW128 in force table to force it...
3,045
I am Trying to make the analoge output of the expansion module follow the oppisite of the analoge input on the device. So, when I have 0 volts on...
2,086
