omron cj1m analoge inputs not working
Red_inc
Dec 2013
schiedam
I have a omron cj1m-11cpu with:
3x cj1w-id211 (16 inputs)
3x cjiw-od212 (16 outputs)
and a mad42 (2 anologe outputs 4 analoge in puts)
I wrote a plc program ( normally i work with step 7)
but this time its in omron i have a bit of omron schooling
did a base and data course.
any way the digital i/o part of my PLC program is functioning fine, but i can't get the analog inputs to work.
I did read the threads here on the forum, looked at example programs but i can't get any analogue input signals ( i have not tryed the outputs)
the 3 input signals are 0 to 10 Volts
and i have to send out 2 4-20mA signals
the resolution is set @ 4000
card address is set to start at 2000
if you look at the program analogue signals i move the
incoming cio to a D to process the data but i'm not getting any signals...
I have never used an MAD card so will have to have a look at the addressing later as I am on my way out the door.
Observation - where you have your compares they will not work. You have > and =, < and = in series with each other. Both conditions will never be met. You can use them in parallel or just use <= and >= as this takes in both conditions.
Will have a look at the rest when I have time.
I also notice that in the setup for the card you have selected 0-10v for the inputs but further down the range setting is 1-5v - this may be causing an issue.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
255
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
171
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
167
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
323
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
523
