1746-sm1
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Looking for info on this card...not found at ab.com so far...
It is a chassis mounted card with 3 round ports on it each of which is connected to the scanport of a 1305 drive...possibly a really old obsolete unit...
All help appreciated...
Paul
EDIT: Got the part number from a drawing, I can't shut down the line to pull the card to verify that it's accurate though...the front of the card is as I describe with cables plugged into it where a typical card usually has a door...no markings on front except "scanport" and 3 channel indicator LEDs...
Hey that's it, thanks...I always thought the 1203-SM1 modules were the din rail mounted ones that stand alone...learn something new everyday, and amazingly fast on this site...
Hello Upgrading to a ControlLogix processor using existing 1746 I/O (If it ain't broke why fix it?) Main Rack 0 - 13 Slot Chassis Expansion...
2,691
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
195
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,033
Happy Friday everyone! I recently installed a new module, 1746 NIO4I, into the last slot on this chassis. Got the normal IO mismatch fault, added...
1,586
Does anyone know where to get either new or aftermarket 1746-N3 connectors and cables for SLC 32 point discrete in cards? I have a used MCC that...
1,248
