1747-CP3 Cable question
Nov 2013
Michigan
532
This past weekend I created a "Cable Voltron" where I use an Ethernet Patch Cord as a base and put different ends on it (example: https://www.amazon.com/StarTech-com...F8&qid=1465385000&sr=8-2&keywords=rj45+to+db9 ) depending on what I'm using it for.
So far, I've been able to go online with a Micrologix 1400 via DF1 as well as go online with a SLC 5/04 with the RS-232 port in DH-485 mode.
So the reason I'm asking is that in my null modem configuration (Straight-Thru DB9/RJ45, Patch Cord, Null Modem RJ45/DB9) it is not quite wired up like a CP3 cable. I am swapping pins 2 and 3 (RXD and TXD) as well as pins 7 and 8. However, due to lack of resources I did not jumper pin 1 to pin 6 on either DB9 side, nor did I swap pins 4 and 6 in addition to the others like on a true CP3 cable.
Even so, it appears to function just the same. I can auto config in RSLinx, go online, edit online, etc. It appears I have full functionality.
So my question is, what is the necessity for jumpering pins 1 and 6 and swapping pins 4 and 6 in the 1747-CP3 cable? will not having this in my cable hinder my ability to connect to anything? I'm thinking maybe some legacy A-B PLCs that need this, but I don't know for sure.
I have a quick question about a control logix cable. Just about any laptop that you buy now has no serial port on it, only usb. I just bought a...
6,662
Hi! I have a new laptop and he doesn't have a COM port. I've tried to communicate with a SLC 5\30 using a 1747-UIC and a RS-232 cable, and it...
22
80,718
There is on 1747-L532 processor two connectors - DH485 and RS232. Is it any advantagies of PIC system comparing with CP3 cable? In my opinion...
4,744
Hey guys, Setting up my new laptop on windows 11. Got all my software working in Ethernet/IP. Now i'm trying to connect into older PLC running...
1,360
Good Morning , I'm getting ready to replace some old laptops with Window's 10 laptops. What would be the USB version of the 1747-CP3 ...
1,413
