krakenfan69
Hi guys. I'm working on a DH+ system that has RSView32 , PV550 and a PLC5 connected to it. I am adding a ML1400 that messages through Trio radios to 2 ML1100's on RTU's. I want to be able to have the RSView32 read the bits directly for alarming from the ML1400. The ML1400 (192.168.20.12) has all the info I need and so I don't need to "see" the ML1100's. I have set up a CLX chassis with a 1759-DHRIO (node10) and a 1759-ENBT (192.168.20.13) to bridge these networks. From the View32 computer I can see the DHRIO card, drill into it and see the Ethernet card, but I cant see the ML1400 on the other side of it. The ML1400, TRIO, 1756-ENBT are all connected via a Wiedmuller switch. In the ENBT I set it's IP address and the Network mask to 255.255.255.0. Do I need to set up a primary server or secondary server? I haven't entered the IP of the target ML anywhere I assumed it would find it through the switch after looking through the ENBT.
What am I doing wrong?
Thanks,
Kraken Fan #69
Thanks,
Kraken Fan #69
