1756-DHRIO as adapter (not scanner)
keenanstahl
Jan 2007
Wisconsin
I am updating an existing SLC to CLX. The SLC had a 1747-DCM adapter that was a slave to a PLC5 RIO scanner. Can a 1756-DHRIO card can be configured as an adapter? If so how?
The PLC5 is not my equipment and I would like to avoid modifying the configuration.
No, the 1756-DHRIO cannot be configured as a RIO adapter.
You will have to connect this ControlLogix to the PLC-5 in another manner.
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
419
I am trying to send some datas from PLC-5 to control logix plc through 1756-DHRIO. When I go online to PLC-5, Message instruction gives error &...
3,375
:banghead: Remote I/O The occasional times i have had to deal with blue hose/PLC5 I/O addressing it always wrecks my head. Now i am working on...
3,290
Called to a site and am neck deep currently ;) running, but issues. Phase 2 completion has been running for almost 2 years no issues. Controller...
1,638
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
3,009
