1756 dhrio/edh
BenL
Feb 2015
Florida
26
Hello,
Can anyone shed some light on why this DH+ module is inactive in device tree? It is the comm path for a level (F22:0, PLC5/40) that keeps freezing up causing valve issues. The level is an message instruction (MSG11_006. L5, R2) in the 1756 CLX. The level there is fine and updates on scans. From what I've been told, this issue only starting happening recently. It was an existing configuration. I did notice the path on the MSG instruction setup screen shows Ch. A, Dest node 74. When I view it from the PLC5, it shows, Ch. B. But there is no connectivity. Controller shows fault on slot 9 (DH+ module), no connection instance, 16#ff00. The signal at the PLC 5 seems adequate 235mA fluctating. Thinking possibly a bad module, or configured incorrectly? Any input would be appreciated.
Link to both projects:
https://www.dropbox.com/s/udwgqpyaqu7vh1b/Valves.zip?dl=0
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
431
I am trying to send some datas from PLC-5 to control logix plc through 1756-DHRIO. When I go online to PLC-5, Message instruction gives error &...
3,396
:banghead: Remote I/O The occasional times i have had to deal with blue hose/PLC5 I/O addressing it always wrecks my head. Now i am working on...
3,301
Called to a site and am neck deep currently ;) running, but issues. Phase 2 completion has been running for almost 2 years no issues. Controller...
1,641
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
3,016
