1756-HSC Encoder x4 max frequency?
Paul351W
Mar 2008
Northern Illinois
154
I've read through the user manual for the HSC card, and it mentions a max of 250kHz in all Encoder modes (x1, x2, x4) but the manual does not specifically say if that frequency limit is the raw pulse train of one phase (A or B) or if that applies to both pulse trains?
I have used the HSC module before on a 120 tooth speed wheel on a shaft that only saw ~2000rpm so there were no concerns about exceeding the frequency limit. My current application has a 768PPR encoder on it, and will potentially spin up to 5000+rpm (64kHz) so I am worried using X4 mode could potentially put me up to 256kHz, which is out of the card's range.
Also, on my previous setup I used one channel of the card in Encoder X4 mode, and the other in Frequency rate mode to measure frequency because the Frequency mode doesn't give direction, and I discovered the reported directional frequency from the X4 mode updated slower than the Frequency mode data. Anyone else run into this issue?
Hello. So we have a machine with a carriage run by a VFD driven motor. I have noticed that for some reason it periodically loses 720 pulses and...
2,920
I'm sorry , this is one of those dumb ones. I have a Line Driver Output Encoder going backward on a 1756-HSC. Am I correct in saying thatI can...
2,046
Hello OK what i have is a prince diecast machine with 4 encoders on the tie bars to measure the tie bar strech that give me the tonage of the...
3,706
I have a Red Lion model ZMD encoder which I would like to interface to a 1756-HSC card in a Logix rack. The input connection details are a little...
2,529
I am getting ready to purchase a 1756-HSC ( High Speed Counter Module).To keep cost down I was thinking of purchasing Incremental Encoders...
2,933
