1756-HSC / Line Driver Output Encoder going backward
Rob S.
Sep 2008
Maryland
739
I'm sorry , this is one of those dumb ones. I have a Line Driver Output Encoder going backward on a 1756-HSC. Am I correct in saying thatI can swap Out A+ and Out A- , Out B+ and Out B- , Out Z+ and Out Z-to change the direction of what I am seeing in my program.Thanks in advance,
I switched Out A+ and Out A- , Out B+ and Out B- , Out Z+ and Out Z-to change the direction , and it is still counting down. Is there something I needto change in the 1756-HSC ? Thanks,
I believe there is a configuration setting to change direction but I'll address the wiring.
Method 1, swap A pair with B pair keeping polarity
Incorrect Correct
A+ -> B+
A- -> B-
B+ -> A+
B- -> A-
Z+ -> Z+
Z- -> Z-
Another method, but perhaps more confusing, invert just one pair
Incorrect Correct
A+ -> A-
A- -> A+
B+ -> B+
B- -> B-
Z+ -> Z+
Z- -> Z-
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
934
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,302
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
Our ABB Vision System requires a Pulse Train Input from an Encoder (12-15 VDC)to calculate the speed of the web. Instead of adding an encoder to...
1,566
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large. 1746-HSCE uses M0:e.1/4 for a...
1,655
