tlona
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per second. The Application is Flow and I have seven (7) pulse meters that provide 1600 pulses per gallon at a flow rate of 3gpm. The HSC module only has two inputs and therefore need eight (4) 1756-HSC modules. Thank-you
