odwyerpw
Supporting Member
Folks,
Putting together a system utilizing a Control Logix Gen 8 (5580) PLC w/ the L83e CPU.
I'll be connecting to 8 different FLEX-IO drops. Each drop has a 5094-AENTR for comms w/ less than 5 FLEX IO modules (hence no need for the 5094-AEN2TR).
Because Flex-5000 communicates at 1GB using the CIP protocol, I wanted to install the 1756-AN4TR Ethernet Adapter in the 5580 chassis. However, it's a Unicorn right now and vendors are charging about 250% above list price.
I'm asking if the 1756-AE2TR, which communicates at 100MB using the CIP protocol is valid option. I only have the 8 drops, and most of them have between 4-5 (1 has 6) io modules and none of those are high speed counters or such.
I cannot find specifics in the Allen-Bradley literature, whether or not this is a valid configuration, 1756-AE2TR (100MB) to 5094-AENTR (1GB that will be forced to 100MB I imagine). Will it have acceptable performance?
We have a plethora of 1756-AE2TRs driving 1794-AENTR on 6th and 7th gen Control Logix PLCs. Never an issue with 100MB performance on the 1794-FLex solutions.. Just don't know if it will be with FlEX-5000.
