Using 1756-RIO to read weigh scale indicator?
TheIndian
Jun 2017
Virginia
Can you use the 1756-RIO to read values from a weigh scale with a RS-232 port? I am looking into trying to bring in data from the weigh scale that has a bidirectional RS-232 port.
Welcome to the PLCTalk forum community !
The 1756-RIO is a scanner module for the old proprietary Allen-Bradley Universal I/O network. There are several A-B platforms that used that protocol and wiring, and dozens of third-party devices that integrated adapters and plugs that used it, including weigh scales.
But it's not the same as RS-232. You would need a programmable device (I can think of a handful, none of them modern, cheap or powerful) to bridge between the RIO network and the RS-232 port.
There are many EtherNet/IP based gateway devices that would be less expensive, faster, and easier ways to connect between a ControlLogix and a weigh scale with an RS-232 port.
The HMS Communicator is cost-effective and flexible.
Red Lion, Prosoft, Hilscher, and Real Time Automation are all popular vendors of similar devices.
I have communicated to a PLC 5 via Ethernet network by using 1756-DHRIO from peer communication port DH+. But is it possible to communicate to a...
2,166
Curious if this is possible. I am working on a PLC5 to CLX conversion. Due to panel space limitations and time I need to replace a small PLC5...
3,505
We have DH+ network on 6 PLC5. We have RSView32 as a HMI. Previously we link HMI with DH+ network by 1784-KT card but we have a problem on some...
3,029
Hi there, We have panelview plus installation on DH+ network. Recently we moved from PLC 5 to CLX. Due to CIP connection limitations to optimize...
4,093
The cards have two internal 3.15A fuses, one for each group, and a 0.5A max current loading per point @ 60°C (140°F). They also have a 5A surge...
1,075
