Micromotion pulse input to 1756-HSC
phuz
Jun 2008
Mohnton, PA
1,044
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the micromotion mass flow meter. A+ / A- on the old card, and electrician hooked up to terminals 14/18 on 1756-HSC which looks like 12/24vdc and I'm wondering if the A+ needs to be on #16 for +5vdc. I can't find any info on what voltage the micromotion pulse is, but I would suspect 5.
Having a strange issue where the totalizer seemed to be operating correctly, and then on the next batch it was completely off. I also have the 1756-HSC on Counter mode with no filter enabled.
The micromotion is scaled to 60 counts per lb and they're running at 30lb/minute and showing 30hz on the micromotion pulse signal, which jives. However, the PresentValue is showing the count increasing at a rate of about 700 / sec. Not sure what's different on this card vs. the other. I did enable the filter which is good for anything below 25khz. I also just realized that the card in the program is a HSC/B and the actual card is a HSC/A. Keying disabled. Would that have an effect here?
Found the culprit. The customer had the signal wires run along/near 120vac VFD control wire and whenever it was energized it would take the incoming meter signal from 30hz to ~700hz. Temporarily ran a wire directly from the meter to the HSC inputs and no issues.
Hello, I have a quick question hoping to get some clarity. I am working with a RSlogix 5 program where a PLC5 processor is communicating via...
2,623
I have a project using a Micromotion 1700 Series Transmitter and Allen Bradley 1400 PLC. I need to communicate over RS485 to the AB Channel 0...
2,155
Has anyone used an Automation Direct MB-Gateway modbus tcp to rtu gateway on a MicroMotion RFT9739 transmitter? We are able to get modbus rtu...
1,587
Looking over this micromotion meter pulse output to PLC input I think i need a 1756-IV16 input. Has anyone else wired this meter to a...
6,165
