Micromotion Coreolis to Allen Bradley MicroLogix PLC Communication
Welcome to the forum.
We will need a lot more info. about your set up in order to help.
What PLC model are you using? What is the Meter Model? How are you communicating to it Modbus I assume?
The more you can tell us the better chance that we can help.
I've been fighting with a Micromotion 1700. Can't get into the configuration area. It's as if the optical sensors are disabled or locked out...
67
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,314
Hello, I have a quick question hoping to get some clarity. I am working with a RSlogix 5 program where a PLC5 processor is communicating via...
2,646
I have a project using a Micromotion 1700 Series Transmitter and Allen Bradley 1400 PLC. I need to communicate over RS485 to the AB Channel 0...
2,172
Has anyone used an Automation Direct MB-Gateway modbus tcp to rtu gateway on a MicroMotion RFT9739 transmitter? We are able to get modbus rtu...
1,601
