1756-hsc
wsteve
Nov 2008
Florida
Our ABB Vision System requires a Pulse Train Input from an Encoder (12-15 VDC)to calculate the speed of the web. Instead of adding an encoder to the roll, I would like to send it a pulsed signal (240 ppr) created by either a third party device (4-20ma to 240 ppr) or maybe using a 1756-HSC. I would appreciate information on either solution. I am unable to determine if the 1756-HSC can generate this output signal. Thank you for any help.
I just finished a system last week where an ultrasonic scanner needed an encoder input. The scanning head was servo driven, so rather than mount a dedicated encoder, we used one of these:
https://ab.rockwellautomation.com/Motion-Control/Servo-Drives/Encoder-Output-Modules
A MAG instruction (Motion Axis Gear) is used to set up gearing between the kinetix 5700 servo axis and this encoder module, which then outputs pulses just like a real encoder.
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
932
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,301
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large. 1746-HSCE uses M0:e.1/4 for a...
1,655
What is the best way to detect a wiring issue on a 1756-HSC. To detect a wiring issue or the data is not accumalating (Totalizer).
1,647
