1756-IB16S 16 channel safety input card for 5580 guardlogix controller issue?
Narko
Mar 2017
New zealand
Hi all,
We tried to setup the hardware onto a 10 slot rack as follows,
PS
Slot 0: 5580 controller
Slot 1: Safety Partner
Slot 2: Safe Inp
Slot 3: Safe Out
Slot 4: Network comms card
Slot 5-9 empty
So here's the issue we've been getting.
All parts are out of box.
Safety output card has a solid green OK and we're able to read the module info and reset ownership.
Safety input card has flashing orange and green OK. And can't get module info or reset ownership.
Tried different slots but no luck.
Can someone please she'd some light on the issue.?
Tia
Card must go in the slot you set up for it in the hardware tree???
Are the inputs configured in the module?
Is your safety network number consistent? (Not sure if that's a thing for local I/O)
DO YOU HAVE an error mesage and code in the module properties?
Manual does not list "flashing orange/green"
It does say that "flashing red/green" means you must commission the Unique Node Identification Number.
Does the yellow yield sign show by the module in the hardware tree?
Fun Fun Rockwell.
Fun Fun Rockwell.
Yes that's what's happening. How do we commission the UNID number.?
"For a backplane port, an SNN is assigned to the backplane and the node
address is the slot number of the device."
" each subnet is assigned a unique Safety
Network Number (SNN), and the UNID is created from the SNN + the
Node Address. "
"CIP Safety I/O modules retain their UNID (SNN + Node) once it has been
assigned, and must be reset before they can be reused with another value."
Publication 1756-RM012D-EN-P - August 2020
Safety Reference Manual
I'm just reading... Hope it helps...
Like I asked before, is your safety network number consistent?
You can find this number in the safety processor properties, I think.
Or the Output module properties.
Then enter or paste into the Input module properties.
Reset the module first, I think.
I haven't run into this UNID thing before, but I think it basically just means you need the SNN to match the Safety PLC and other modules. And reset the module if you change slots. Prolly a new-out-of-the-box module would create its own setup when it is configured, but this one had issues.
Yes we have come to the conclusion it's a dodgy card.
We got swapped it from one slot to the other, it works for 10 seconds with solid green OK and then gets lost in communication timeout errors.
We're organising a replacement part.
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
64
361
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
158
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
92
