1756-IF16 analog input module
BENNY
Mar 2003
22
I have a 1756-IF16 module wired for single-ended inputs,that has 2 channels (6 & 14) which will go to zero randomly.I have swapped out the module and the problem still remains.I have removed the inputs and the 2 channels still go to zero randomly. Has anyone experienced this and were you able to fix it? Any help would be greatly appreciated,thank you in advance.
1st check I would do is ...
verify that all the devices are 2 wire loop powered devices. In addition, make sure that this is only one power supply in the loop.
Hello, we chose Allen-Bradley analog card 1756-IF16 for three 4-20mA current inputs for XFMR high side winding temp, low side winding temp and...
2,769
Good Evening , I’m getting ready to integrate a Mettler Toledo IND 570 into a ControlLogix PLC , Analog 4-20 ma input card 1756-IF16 . I’m...
2,324
Good Evening , I have a 1756-IF16 Analog Input card already installed in a working ControlLogix Rack. I need to add another Analog 4-20 ma...
2,191
Hello PLCTalk Friends, I am interested in connecting one 2-wire loop powered 4-20mA transmitter to two analog input cards. In my program, I will...
1,404
Is there a way to see what the actual field signal value is going into each channel of the Analog Input I/O card 1756-IF16? In other words, I...
3,669
