1756-if16 discontinuation?
diat150
Mar 2006
Louisiana
1,476
Just got a note from my distributor that says this module is being discontinued 12/2021 with no direct replacement until 08/2022? They then said work with engineering to find a replacement. WTF?
This is the wording from the distributor. I had a buddy call his distributor in a different state and they said basically the same thing. My guess is they will be changing chips or something.
The series A version of this product is scheduled for
discontinuation 12/15/2021 with no direct replacement
expected until August 2022. Please work with Engineering to
find an alternative solution.
Seems like techconnect has an answer for that: BF27273
Seems like due to supply chain shortages, they can't support 'Series A' and the 'Series B' isn't going to be available till next year... Seems like they do offer engineering replacements though.
Regards,
-PreLC
467
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
169
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
124
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
978
I have an existing 1756-IF16 wired as single ended with all RTNs tied together. Channels 0-3 have 2-wire loop powered devices connected with all...
1,088
