1756-IF16 Issues
DennisCotten
May 2011
Redcliff
34
I have a two 1756-IF16 in a 17 card chassis with a L72 processor. I have the cards configured for 0-20 mA, low raw 4 mA, High raw 20 mA, low EU 4000 and high EU 20000. All of the inputs on this card are configured the exact same and are all reading the exact same number. It is just about 0 mA, but very slightly above. The electricians have measured 4 mA coming into the cards inputs. I am at a loss on what could be causing this and looking for any kind of ideas. I believe that there are possible wiring issues going to the car being as this is a brand new panel, but not certain.
sorry, is the sensor a source or sink? can you show me how it is wired? what kind and model of transducer do you have connected to the inputs
+24 VDC going out to the sensor on the white wire off of the power distribution. The signal comes back on black, which ties into the analog input. And the ground wire is tied to ground.
all of the RTN's on the right side of the terminal block on the card are tied to -24 VDC. But from what I remember, any of the RTN's on the left side of the terminal block (side with inputs) aren't tied into anything.
I migrated from a 1771-IFE to a 1756-IF16 using the conversion kit about 6 months ago. Everything seems to be working except when I went back and...
1,284
403
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
157
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
109
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
976
