EICS
I would like a sanity check on an application i am working on.
I have a proximity switch counting pulses with a Mark/space ratio of 1:1 on a rotating shaft. 1 pulse per revolution.
the prox is fed into a 1734-IB8 point I/O with an RPI set for 20ms. the CPU is a 1756-L72S with Safety Partner
I am loosing pulses when I go above approx 290rpm (290 PPM) so that is about 5hz. the filter on/off time setting on the module is at default (1m/s from memory)
maximum speed of shaft I am expecting is about 340RPM ( or less than 6 Hz) so I am close to what I require.
I am using a counter to get the pulse rate every 15 seconds then dumping that value into a register then resetting counter. and multiplying the register value by 4 for a rate/minute. the application is to compare head roller speed of a conveyor to the tail roller speed to check for slippage hence the 15 second sampling, I need to alarm & shut-down to save mechanical issues on belt if slippage or a jam up occurs.
should I be looking at a periodic task specifically for this subroutine or any other things i should be aware of?
