1756 L81 out of box SD flashing red LED-no valid SD exists
bigLee
Jun 2018
Florida
77
Hello,
Before i reach out to local supplier, figured I'd ask here regarding this issue. Right out of box, the controller had a solid red SD LED. Indicating it does not recognize SD card. After a couple downloads with my application, it is now flashing which per the manual indicates SD card does not have a valid file system.
Within the controller properties I cannot load/store and the message indicates no SD card installed.
Any ideas or does this need to go back for return?
Thanks!
Do you have another SD card ? odds are its just the card, I had a bad one about a year ago
Reset to factory default with paper clip, reflashed and was able to store to SD. Maybe a glitch during initial flash?
Not sure if this is related but also have the PLC plugged in and get to a good operating temp and then power cycle the PLC.
I also thought the PLCs could run without an SD card but I only have a very limited experience with the new PLCs. I just know I froze one (temperature froze) and the PLC faulted.
Hello, I had an out of box controller 1756 L81 Contrologix. Was running for about a week and started getting the ESM fault. Powercycling did...
2,666
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
71
367
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
161
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
