1756 L81 out of box SD flashing red LED-no valid SD exists
bigLee
Jun 2018
Florida
77
Hello,
Before i reach out to local supplier, figured I'd ask here regarding this issue. Right out of box, the controller had a solid red SD LED. Indicating it does not recognize SD card. After a couple downloads with my application, it is now flashing which per the manual indicates SD card does not have a valid file system.
Within the controller properties I cannot load/store and the message indicates no SD card installed.
Any ideas or does this need to go back for return?
Thanks!
Do you have another SD card ? odds are its just the card, I had a bad one about a year ago
Reset to factory default with paper clip, reflashed and was able to store to SD. Maybe a glitch during initial flash?
Not sure if this is related but also have the PLC plugged in and get to a good operating temp and then power cycle the PLC.
I also thought the PLCs could run without an SD card but I only have a very limited experience with the new PLCs. I just know I froze one (temperature froze) and the PLC faulted.
Hello, I had an out of box controller 1756 L81 Contrologix. Was running for about a week and started getting the ESM fault. Powercycling did...
2,687
Hey Guys, I thought I knew the answer to this, but after some looking I am starting to doubt myself. I thought the 1756-EN2TR would allow you to...
73
We had a site where a rat gnawed through some fiber optic cables which (obviously) prevented communication to a remote rack entirely. We, and the...
95
We are in the process of converting our plants from PLC5 controllers and 1771 I/O into ControlLogix PLCs and Logix I/O. Up until now we used 1756...
78
Hello all, I have a 1756-EN2TR dual-port Ethernet IP Module attached to my 1756-L73 PLC. I currently have hazard symbols over both the top and...
172
