1756-L82E PLC tags values backup
doomsword
Aug 2016
Zagreb
201
We have 1756-L82E PLCs here and now we have issues with one PLC having a lot of used program memory, which bothers the client, and wants us to reduce memory usage.
We have some parts of software which is executed only once, at startup, basically used to initialize constants, PID regulation parameters, recipes etc.
So my bosses have idea that we can delete this part since this PLC apparently backups working memory (values of tags), everything is retentive and nothing should be lost at powerdown.
So are they correct about this? Can I simply delete this part, since all these various constants are saved when powered down?
We upgraded a machine which had 1756-L62 Ver 15 to 1756-L82E running version 32. Every once in a while the processor faults with Type 01 Code 61...
3,329
Hi guys, seems that our HMIs are making too many CIP connections to PLCs (application connections) and we reach 256 max limit. After that no...
2,959
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
69
365
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
161
