grison
Guest
G
Has anybody used 1756-PLS module.
can you please comment about it.
I just want to know whether i can use the 16 Digital inputs available in that card for
reading fast response inputs comming from my photo and proxy sensor.
is that digital inputs fast response type.
Can i use that 16 digital input present in that card for other purpose than for PLS function. is that possible.
Also can i use any Resolver or should i have to use it only with Allen Bradley 846SJ industrial resolver as said in manual.
why have they kept it to be used only with AB resolver. which doesnot solve the purpuse for us as we just wanted only
to replace the external panel mount PLS module to PLC based PLS. but now we cannot use our existing Resolver and now we need to
change to new AB resolver, coupling, mounting etc.all added work.
Also if i cannot use my 16 digital inputs for reading fast inputs, then i just wan to know is there any equivalent card
for 1771-IT.
thanks
grison
for 1771-IT.
thanks
grison
