Allen Bradley 1756 PLC - Encoder for PLS Windows
johndemasters
Dec 2018
Fort Worth TX
Hello All
I have an older machine that has an existing Electro Cam PLS.
I want to look to replace this system and add an encoder to capture the machine position and create CAM windows for functions in the PLC.
Anyone have experience with this - Allen Bradley 1756 Control Logix PLC.
I've asked AB for help and they tried to get me to purchase an ANCI PLS Card and that is not what I'm going to be allowed to do.
I want to add an encoder - card in the PLC and create my own 0-360 scale.
Thanks in advance
363
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
209
Dear All: I have the flashing red light on the FDBK indicator. The manual said that it means: The axis servo loop error tolerance has been...
639
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
909
