1756-RIO- Adding a input module
dcam
Apr 2012
Merced Ca
161
I have never understood how the I/O is configured using RIO. In the tree there is only the RIO module, not the racks of I/O attached or all the individual module definitions. I am also uncertain as to how the tags are generated for I/O. Perhaps in the Data Types folder? I see 1756 DHRIO cards out there also.
Are you using 1756-DHRIO, the classic DH+ and RIO modules from Allen-Bradley, or the 1756-RIO, which includes the guts of the QTS RIO scanner that is also sold standalone by Prosoft ?
The 1756-RIO has a configuration applet that sets of all the racks and block transfers, while the 1756-DHRIO has Adapter objects in the ordinary I/O tree.
1756 DHRIO TO A SLC500 1747 RIO ADAPTER. I'm gonna hit the Rockwell knowledge base tonight and try and figure this out. We still have a lot of this old RIO stuff here and its been a mystery to me for to long....Thank you sir.
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
2,997
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
414
I am trying to send some datas from PLC-5 to control logix plc through 1756-DHRIO. When I go online to PLC-5, Message instruction gives error &...
3,375
So I'm looking at replacing some obsolete Prosoft boxes that currently convert DH+ to Ethernet. I have a logix chassis that already has a...
2,908
:banghead: Remote I/O The occasional times i have had to deal with blue hose/PLC5 I/O addressing it always wrecks my head. Now i am working on...
3,288
