1768-ENBT problem
Joel201
Nov 2013
Calamba City
151
Good day,
I have a 1768-L43 PLC and 1768-ENBT. My setup is Power Supply,1768-ENBT,1768-L43,ECR. I have used the Bootp to place an IP address to the 1768-ENBT i have disabled the Bootp and checked the module if it has an IP and it shows the IP i have input and then cycle power to the units and check if the IP is still there and it is still there. Now my problem is that when i connect my ethernet cable to the 1768-ENBT and then try to configure it in RSlinx by selecting the EthernetIp I cannot see the ethernet module just the default windows and my PCI card i am using rslinx v2.57. Thanks in advance for your help guys.:site:
*EDIT I can Ping the Ethernet module with CMND so i am confused why it doesn't show in RSLinx
Regards,
Joel
Is your computer configured for the same IP subnet as the 1768-ENBT ? But with a different IP address, right ?
Try the "Ethernet Devices" driver in RSLinx Classic.
The "EtherNet/IP" driver uses a broadcast packet that can be blocked by some firewall software, while the "Ethernet Devices" driver uses a TCP connection to the devices you put in the Host List for the driver.
How about if you use the Ethernet Devices driver and manually type in the IP address? Can you connect to the module through it's embedded web page?
Thanks for your replies guys.. it seems that my ip should be within 169.254.15.x when i changed into that IP i can see the PLC in RSLinx. i haven't read anything about using a fix pattern of ip when configuring the Ethernet module. Maybe i just didn't look close enough by the way thanks again :p hehe
Regard,
Joel
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
286
Good Evening, I've spent most of the evening working on adding a 1768-ENBT card to connect a machine to our enterprise network. The card is...
1,500
Can a L36ERMS use an ENBT (or other rack mounted ethernet?) module to connect to PoitIO 1734-AENTR? We have a system coming in that has PointIO...
2,635
Hi All, I have a 1768 L43S Guardlogix controller FW 19 with a 1768-ENBT A module in the rack. This unit was purchased 2nd hand, and the...
2,731
Hello everyone, I have two 1768-L43 controllers. In each chassis are two 1768-ENBT modules. In chassis A, there is one with the IP...
2,077
