1769 ASCII 2 Channel Module with L32E Processor
George07
Jul 2012
Port Elizabeth
Good Day
I'm using a 1769-ASCII 2 Channel Module with L32E CompactLogix Processor. For some reason I cant seem to send data. I looked at the sample code on the Rockwell website and that is for a Generic Module with L35R processor and none of the tags match.
I tried to increment the TransactionID (said in the manual) but nothing happens. Could the delimiters be a problem?
I'm communicating with a Mettler Toledo IND560 Scale Terminal via RS232. o_O:mad:
I need help to develop an application that can send and receive ASCII data in both channels 0 and 1 simultaneously. The sample is attached to the...
1,630
Hello, I am attempting to use the 1769-ASCII 2 Channel Module with a CompactLogix 1768-L43 Controller to connect to two AccuRange AR 700 lasers...
7,945
This is maddening. I'm developing a new application where a 1769-L32E with a 1769-ASCII module is communicating with a Tegam micro-ohmmeter...
1,586
so, Micrologix 1500. 1769-ASCii module. Bringing data in over the Channel 0 serial port. Setup is attached below. As is a snippet of the code...
1,637
I tried searching but either there aren't any answers out there for my Google-fu isn't up to snuff. My customer has a laptop with Labview set up...
1,555
