1769-IF4 vs 1769-IF4I
Holmux
Oct 2013
Aalborg
279
Dear members
I believe I have the difference in the modules correct:
1769-IF4, has one converter handling all 4 input by turn
1769-IF4I, has a converter for each channel, which I would think would be faster, but how much faster?
I have tried to read as much info as possible but haven't had a change to compare the actual difference in real life, do we have anyone at the list that has made a comparison of the 2 modules and can tell me the actual difference in response time from the 2 modules.
Thanks in advance
/Holmux
Hi All, I am working on a small PLC system having Compact Logix LE33 PLC having only two IF4 card. Some of these channels are used for 4 - 20...
1,163
Hello. I'm dealing with a 1769-IF4 module with the "OK" light OFF. Data is not updating in RSLogix5000 - no change when inputs are connected or...
1,819
I need some help. I have a 1769-IF4 analog card that is hooked up to strain gages, the gages give a 4-20ma signal to the card. We had an...
2,035
I have installed 1769 IF4 analog input module in compact logix rack slot 3. I have an existing 1769 8 channel input card in slot 2 already...
2,444
hey guys, I am stuck with a peculiar issue with a micrologix plc unit with an analog input module as an external I/O. I have a micrologix...
1,567
