Hey guys,
Been a while, I have an odd one. Something that should be straightforward.
I have a 1769-IF8 module, looking to add an analog, been in operation for couple years.
I have 6 single ended inputs working on input 0-5 with no problems. With those I obviously have the jumper in place to ANLG COM.
I am adding a 4-wire device to 7th input. This requires connection to Iin 6+ and V/I in 6-. Seems pretty straightforward.
Doesn't work. I moved it to the 8th input, same thing 0mA. I am 100% sure that the ANLG common jumper is not in place.
I moved on of the single-ended inputs onto one of those (with jumper) works fine.
I measure the current inline, 4 mA as expected. When I unpair my remote device, drops to 1.8mA as expected.
Tried 0-20, 4-20 etc.
Also worth noting, when producing 4mA, I see about 1V across terminals and 0.47 at the 1.8mA which correlates to the 250ohm load of the card.
Nothing ever reads into Local CH Data register.
Thoughts?? I'm stumped.
