about the 1769-IF8 used
zhoudq
Jul 2011
JiangSu Province
75
Hello! I have a project, use the software is studio 5000 v30, the 1769-L30ER compactlogix controller, 1769-LIF8 1769-IQ16 and 1769-OB16 modules, now I configuration these modules in the project, the 1769-IF8 module parameters 0-5channels input range:4-20mA,6-7channels input:0-10V, filer: 250Hz, data format: Engineering units. and click the ok, then I design the ladder diagram, if i use the local ch0-5Date in the ladder diagram? or I need the designing the add on instruction in the project and configuration the parameters. please help me, look for word your replay! or give me example datum. thank you!
the software Rslogix 500 have SCP instruction, but software studio 5000 no SCP instruction, so i configuration 1769-IF8 parameter, then can i used the local data direct in the ladder diagram?
Zhou, I believe the answer is yes, if you have configured the module.
Data Tags are created for you. I have not used this and cannot speak directly to it.
I guess I am just saying hello, several years ago I spent a lot of time in Changshu working at the Aleris zinc oxide facility. I miss all my friends there but I doubt that I will ever get a chance to return. I wish you Good Luck with your project!
Hey guys, Been a while, I have an odd one. Something that should be straightforward. I have a 1769-IF8 module, looking to add an analog, been in...
4,450
my customer has a full 1769-compactlogix rack. they want to remove the two cards in slot 5 and slot 6 and replace them with two new cards. The...
1,578
Hi folks, The 1769-IF8 has a ChannelStatus Bit, do you use it? From my reading of the manual, this bit is set when the channel has one of many...
2,269
Can a analog card properties settings such as RTS and filter frequency can be changed with CPU in run mode without causing errors or issues...
1,894
Good Morning , I have a 1769-IF8 analog ( 4-20 ) input card. Using a calibrator, but the 4-20 signal is jumping around . It is not too...
2,771
