phuz
I'm trying to install a 1734-OE2C (F/W 1.003) analog output module with a CompactLogix L16 and the module is coming up with a yellow triangle. Other modules are OK. I disabled keying, but the status shows Connection Timed Out in Logix. If I click on the module info tab under properties, it pops up with "Path specified invalid or module not responding."
Is this another F/W version incompatibility with a compactlogix? I went through a similar ordeal last year with a IE4C on a L18.
I have tried Logix F/W versions of 27 and 20 with same result.
