1769-L31 CompactLogix Controller
Don't know if deleting the HARMONY files would help?
A while ago, probably on here, I read something else in relation to Harmony files. I tried to do a Google search on the subject but, as you may imagine, the results were all over the place. What are they? (Not trying to steal the post here, just a quick question since it was brought up)
"Harmony" files are two internal driver management files used by RSLinx Classic; Harmony.HRC and Harmony.RSH.
Deleting them and allowing RSLinx Classic to rebuild them used to be a common way to clear up RSLinx Classic browsing problems. I haven't had to do that in years.
The specific issue in this thread is, I suspect, related to Add-On Instructions or Add-On Profiles and special Tag Data Types, rather than a generic driver or RSLinx configuration issue.
Ah. I see I get much better results if I throw 'rslinx' into the search! Thank you much, appreciate it.
I need some help communicating with this processor, I hook up I find it under communications tab in rslgx 5000 keeps telling me my path is...
4,555
I'm trying to read data on one of the 2 serial ports on the PLC CPU but dont know how to read this data. The PLC I use one of the ports (CH1) to...
4,859
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
406
Dear All members I have problem about CPU CompactLogix 1769-L31 as follows; Step 1. I connect this CPU 1769-L31 with 1769-PA2 and 1769-ECR...
1,512
Hello all. I would like to know if there are compatibility issues using RSL5000 v. 20.12.79 in a compactlogix with a 1769-L31 CPU? As I attempt to...
2,172
